Apt update errors
Hi there,
I’m on Ubuntu 22.04 and updated to the new version last week and it’s working well so far. Today ran apt update and I’m getting the following error:
Failed to fetch https://downloads.k8slens.dev/apt/debian/dists/stable/main/binary-amd64/Packages.bz2  File has unexpected size (632 != 629). Mirror sync in progress? [IP: 89.187.169.47 443]
   Hashes of expected file:
    - Filesize:629 [weak]
    - SHA512:c850abb...a7cc26c8997fc2d7
    - SHA256:80883...
    - SHA1:6e04... [weak]
    - MD5Sum:df1d... [weak]
   Release file created at: Fri, 17 Jan 2025 16:24:33 +0000
Will this resolve on it’s own or is there a deeper issue?
It resolved on it’s own
Hello eitands,
Thank you for reaching out to Lens forum!
We’re glad to hear that everything is working fine!
