First post,
Recently deployed Azure Managed Prometheus and Grafana. Everything appears to be working as expected.
Now I would like to deploy Lens and connected to the cluster. Lens is not able to locate the services and port number to set up the connection.
Can someone point me in the right direction? Is this set up supported, to Azure Managed Prometheus?
Thank you,
Hi, are you trying to use the Lens Teamwork / Spaces feature or something else? Can you connect to the cluster directly?
I don’t’ believe so, I was just trying to set up some dashboards for monitoring. I did get everything working, but I am not certain that I am connecting to the Prometheus collection, and not directly to the cluster. Obviously, I would like to avoid having two workspaces.
