When I clicked Cmd+P to switch between clusters I saw three times each cluster
Hello @realhuseyn
Thank you for reaching out to Lens support!
Thank you for reporting a bug.
We are working on your issue. Stand by for further updates.
Regards,
Oleksandr from Lens
Hello @realhuseyn,
thank you for your report. Does the duplicate display of the same cluster occur only in the Command Palette (Cluster Search), or is it also visible in the Navigator on the left?
If it also appears multiple times in the Navigator, please check the synced files or folders under Preferences > Kubernetes >Manage Kubeconfigs in Lens. It’s possible that you are referencing the same kubeconfig files via file- and folder-sync multiple times.
Looking forward to your response.
Hello. No, it is visible only in the Command Palette. Each cluster appears one time in the Navigator
We have observed that when modifying or changing kubeconfigs, the affected clusters are not cleaned up and remain present. As you mentioned, this issue seems to impact only the cluster search and not the navigator. Thanks again for reporting this! I will create a bug ticket, and we’ll plan a fix in one of our upcoming sprints.
