Hi!
I have a cluster deployed by k0sctl with this config:
apiVersion: k0sctl.k0sproject.io/v1beta1
hosts:
- ssh:
address: 192.168.100.61
user: zerum
port: 22
role: controller+worker
noTaints: true
- ssh:
address: 192.168.100.62
user: zerum
port: 22
noTaints: true
- ssh:
address: 192.168.100.63
user: zerum
port: 22
noTaints: true
config:
network:
provider: calico
The cluster works fine until a node is restarted for any reason. When the cluster is fully populated again, I can no longer get any logs. I receive:
Error from server: Get “https://192.168.100.61:10250/containerLogs/default/es-master-1-0/elasticsearch”: No agent available
The logs I get for k0scontroller.service
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.112462 998 remote_available_controller.go:448] \"Unhandled Error\" err=\"v1beta1.metrics.k8s.io failed with: failing or missing response from https://10.96.147.225:443/apis/metrics.k8s.io/v1beta1: Get \\\"https://10.96.147.225:443/apis/metrics.k8s.io/v1beta1\\\": No agent available\" logger=\"UnhandledError\"" component=kube-apiserver stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.112531 5309 server.go:579] \"Failed to get a backend\" err=\"No agent available\" dialID=9178363639299553498" component=konnectivity stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.114942 5309 server.go:579] \"Failed to get a backend\" err=\"No agent available\" dialID=3340364227193805717" component=konnectivity stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.114970 5309 server.go:579] \"Failed to get a backend\" err=\"No agent available\" dialID=533201712653154451" component=konnectivity stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.115484 5309 server.go:579] \"Failed to get a backend\" err=\"No agent available\" dialID=7854035195788166003" component=konnectivity stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.115616 5309 server.go:579] \"Failed to get a backend\" err=\"No agent available\" dialID=8014857067551678884" component=konnectivity stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.115672 5309 server.go:579] \"Failed to get a backend\" err=\"No agent available\" dialID=1925891275905775483" component=konnectivity stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="E1008 13:01:14.116181 998 controller.go:146] \"Unhandled Error\" err=<" component=kube-apiserver stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="\tError updating APIService \"v1beta1.metrics.k8s.io\" with err: failed to download v1beta1.metrics.k8s.io: failed to retrieve openAPI spec, http error: ResponseCode: 503, Body: error trying to reach service: No agent available" component=kube-apiserver stream=stderr
Oct 08 13:01:14 kubernetes-1 k0s[709]: time="2024-10-08 13:01:14" level=info msg="\t, Header: map[Content-Type:[text/plain; charset=utf-8] X-Content-Type-Options:[nosniff]]" component=kube-apiserver stream=stderr
The kube-system pods look fine:
$ kubectl get pods -n kube-system
NAME READY STATUS RESTARTS AGE
calico-kube-controllers-97f5949fb-8p2pw 1/1 Running 0 37m
calico-node-plzpv 1/1 Running 0 65m
calico-node-qrljg 1/1 Running 0 65m
calico-node-vc72k 1/1 Running 0 65m
coredns-679c655b6f-jqcpc 1/1 Running 0 65m
coredns-679c655b6f-n7xqq 1/1 Running 0 65m
konnectivity-agent-45wbr 1/1 Running 0 65m
konnectivity-agent-br58g 1/1 Running 0 65m
konnectivity-agent-vm47x 1/1 Running 0 65m
kube-proxy-6kzlm 1/1 Running 0 65m
kube-proxy-j9pvb 1/1 Running 0 65m
kube-proxy-lkxv6 1/1 Running 0 65m
metrics-server-78c4ccbc7f-6vdhv 1/1 Running 0 65m
What I doing wrong?
Thanks in advance!
