Error loading Cron Jobs
Lens: 2025.4.92142
After updating to the latest version (April 9th release) yesterday my Cron Jobs stopped displaying (Cluster > Workloads > Cron Jobs). Instead I get the error below. There is a “Clear Error” button but it does not do anything. This is the same behavior in both clusters I have connected, it was working fine before I updated Lens yesterday
Error stack:
Error: Invalid explicit day of month definition
at new CronFieldCollection (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:8:474975)
at CronExpressionParser.parse (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:8:470558)
at https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:2:3678182
at Object.apply (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:2:7908023)
at renderTableContents (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:2:1086203)
at renderTableContents (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:2:5461987)
at le.getTableCells (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:2:5042703)
at children (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:2:5043376)
at https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:8:1959599
at It (https://lens.app:62772/build/lens.js?4d10baa3cd01f0041efa:8:2015263)
Thanks a lot for your feedback @tutham , and sorry for the trouble caused!
We’re already aware of this issue and are actively working on a fix. It seems to be affecting multiple users after the April 9th release, and we appreciate you bringing it to our attention so quickly.
Thanks again for reporting it — your input really helps us improve Lens. We’ll keep you posted as soon as a fix is available!
Hi im still having the same error on my cron job, im using the latest version 2025.4.92142-latest, please help :frowning:
Can you try to download the latest version and try that? It should be fixed now.
Ok - I was finally able to update to 2025.6.21515. I have been trying every day for a while and most of the time I got a message that said I was on the latest version already (2025.4.92142) even though it had the green “update” button in the banner and I saw newer release notes on the forum. Today the update finally worked.
when I check for updates it says I have the latest version and the problem still persists
Hi @tutham, thanks again for your feedback!
Can you tell us please what is the schedule of the cronjob that is failing?
