Error when connecting to EKS cluster after upgrade to 2025.5.81206
After upgrading to 2025.5.81206 I get the following error when connecting to our EKS clusters:
|INFO|Starting connection ...|
|INFO|Authentication proxy started|
|INFO|Refreshing connection status ...|
|ERROR|E0527 11:20:27.338402 47041 proxy_server.go:147] Error while proxying request: getting credentials: exec: executable aws not found It looks like you are trying to use a client-go credential plugin that is not installed. To learn more about this feature, consult the documentation available at: https://kubernetes.io/docs/reference/access-authn-authz/authentication/#client-go-credential-plugins|
|ERROR|Failed to GET https://127.0.0.1:52269/b8ffe8e448b9e76c314f26108007e333/version: Internal Server Error (500)|
This worked fine in the previous version, and works fine if I try to use the same kubeconfig with FreeLens.
How was aws cli installed? Did you use homebrew or the official way to install it?
The CLI was installed with homebrew
I have this issue too. Aws clusters work, but oci clusters don’t.
INFO Starting connection …
INFO Authentication proxy started
INFO Refreshing connection status …
ERROR E0605 14:39:51.293154 42117 proxy_server.go:147] Error while proxying request: getting credentials: exec: executable oci not found It looks like you are trying to use a client-go credential plugin that is not installed. To learn more about this feature, consult the documentation available at: Authenticating | Kubernetes
ERROR Failed to GET “https://127.0.0.1:49778/6406f80ce8cd9e1b218a19f805d3ed15/version”: Internal Server Error (500)
Hey, thanks for the bug report. Could you check where that oci binary is located in your system by running whereis oci and then could you check echo $PATH if that directory is in your path.
Hi, I was able to specify the full path to where the oci binary was located (usr/local/bin/oci) in the kube config file, and that worked as a workaround.
Regarding your question, my OCI binary was located at /usr/local/bin, and the path is as follows: /usr/local/bin, /System/Cryptexes/App/usr/bin, /usr/bin, /bin, /usr/sbin, and /sbin.
