Hi. I ran into a problem when I start Lens.
It works in the morning, but this problem suddenly appeared in the evening. I nothing changed in the ‘hosts’ file and network settings.
What could I do to fix it?
I tried: reinstall lens, reboot computer, try to launch lens without vpn
logs:
debug: Set kubectl version 1.23.3 for cluster version 1.23.3 using version map
info:
Starting LensProxy
info: [LENS-PROXY]: Proxy server has started at 127.0.0.1:60344
info:
Testing LensProxy connection …
info: [LENS-USER-STORE]: LOADING …
debug: UserStore.fromStore()
info: [LENS-USER-STORE]: LOADED from C:\Users\ayfedorov\AppData\Roaming\Lens\lens-user-store.json
info: [LENS-CLUSTER-STORE]: LOADING …
info: [LENS-CLUSTER-STORE]: LOADED from C:\Users\ayfedorov\AppData\Roaming\Lens\lens-cluster-store.json
error:
LensProxy: failed connection test: d: request to https://127.0.0.1:60344/version failed, reason: self signed certificate
