Hello everyone could someone help me to configure my lens on my mac m1 I am facing difficulties.
With the following message below.
F0518 12:53:31.334161 5039 cred.go:145] print credential failed with error: Failed to retrieve access token:: failure while executing gcloud, with args [config config-helper --format=json]: exec: “gcloud”: executable file not found in $PATH
E0518 12:53:31.334955 5038 proxy_server.go:147] Error while proxying request: getting credentials: exec: executable /opt/homebrew/share/google-cloud-sdk/bin/gke-gcloud-auth-plugin failed with exit code 1
Failed to get /version for clusterId=68694631b615abfc05babf61f6bb7f44: Internal Server Error
F0518 12:53:32.270017 5040 cred.go:145] print credential failed with error: Failed to retrieve access token:: failure while executing gcloud, with args [config config-helper --format=json]: exec: “gcloud”: executable file not found in $PATH
E0518 12:53:32.270608 5038 proxy_server.go:147] Error while proxying request: getting credentials: exec: executable /opt/homebrew/share/google-cloud-sdk/bin/gke-gcloud-auth-plugin failed with exit code 1
Link to print: https://uploadnow.io/files/hckbJB6
