I quit the app, remove /Users/username/Library/Application Support/Lens/kubeconfigs/lens-demo-cluster
The file is re-created upon restart.
In the GUI I cant find anything.
Hello @unwired_splicing052 , Thank you for reaching out ! I have contacted our developers regarding your issue .
Hi @unwired_splicing052 , currently there is no option to opt-out of the demo cluster; however, we are working on bringing a Preference option where you will be able to specify you want to opt-out of it and then the cluster will no longer appear (nor the config will be fetched)
Thanks one would think this would be simple and Iām surprised no one else has mentioned it. I guess everyone else just leaves that there and ignores it.
Anyway looking forward to what the devs come up with ![]()
MIssed it initially, maybe due to my own post had to be approved and came in after your reply.
Either way, thanks for taking the time to reply.
