Is there any way to disable the tabs? Without notice I move between resources and I have 10 tabs opened, I don’t use the old one, I just navigate around and not using them. Why I need them at all?
Dear @davidt
Thank you for reaching out!
We will be sure to update our development team about your request.
Regards,
Oleksandr from Lens Support
Hi there, this is the only behavior we support in the existing released versions; however, we are making changes, so in the next versions the tabs are never persisted unless the user explicitly does it through double clicking the tab, as it works in other IDEs.
Thanks for the feedback, we appreciate it!
