jmakori
1
Hey all!
I’m having issues re-adding my cluster-configuration to Lens… I’ve attempted:
- Refreshing the screen with CMD-R
- Reinstalling/Uninstalling Lens
- Removing cache/leftover files from uninstall
- rm -rf ~/Library/Caches/Lens
- rm -rf ~/Library/Application\ Support/Lens
- Creating a new custom config file Ex) ~.kube/config-lens
And have followed the advice posted on these threads to no success - Please help!
hchen
2
This might be a bug that will be fixed in the next version, meanwhile, have you tried manually sync the newly created kubeconfig as suggested here Cannot see any cluster details · Issue #3891 · lensapp/lens · GitHub ?
Is the problem that the cluster does not show up in the cluster list? Can you share a screenshot of what you’re experiencing?
Ended up getting it working by adding each of the clusters manually - yeah, it seems to be a bug in the functionality
