I have removed a cluster by clicking ‘Remove from kubeconfig’ and then re add that cluster but it is now not showing in the left side menu.
Hello @olebjit
Thank you for reaching out to Lens support!
Thanks for reporting a bug. We are working on your issue. Stand by for further updates.
Regards,
Oleksandr from Lens
