Lens 2025.3.31941-beta - Release
We are happy to announce a new Beta release for Lens Desktop that addresses multiple bugs.
Here’s what you can expect:
  • Fixed loading of clusters under AWS EKS when fetching only partially succeeds
  • Fixed a bug where the Applications view does not respect the instance label
  • Fixed unhandled exception during cluster disconnect
How to access this version?
Switch to Beta Update Channel: Launch Lens, navigate to “Preferences” > “App”, and change the Update Channel to “Beta”. This will allow you to receive this aforementioned update. You can always switch back to “Stable” to go back to your previous version.
