LENS - Issues visualizing Helm_Releases and helm charts
I´ve been having issues with LENS when it comes to visualize Helm Releases and helm charts from a EKS Cluster
I´m getting errors like " LENS Kubernetes IDE issues Failed to write kubeconfig: EPERM: operation not permitted, rename ‘C:\Temp\kubeconfig-direct-2a6c3f16ca0bb0afd8db71b96f2b1ec6.tmp-596883832018795b’ → ‘C:\Temp\kubeconfig-direct-2a6c3f16ca0bb0afd8db71b96f2b1ec6’ "
Also noticed it is creating multiple AWS and HELM processes on Windows and it causing High CPU usage and RAM Usage.
I´ve tried Re-installing, validate Kubeconfigs and other but the issues still persists.
Verify file permissions and used copilot to assist but without success.
After a while i managed to load the Helm_Releases and helm charts but it still generates errors like this and the processes “spam” and the PC starts dying…
Any one have this issue?
Please verify that folder permissions are correct. Lens is not allowed to rename the temporary file.
Thanks for the reply.
Can you tell me which permissions should be given/changed ?
Best Regards
Please verify that rename is allowed for Lens in that location
For anyone wondering or needing a fix for this like me, it was a Windows Folder Permission issue (basically gave more permission to my local windows user on the specific folder)
Thank you @phorsmalahti for the suggestion given.
Best Regards
