I have configured the Victoria metrics cluster to collect and store all the metrics on my K8S cluster.
But Lens doesn’t get any of those metrics. So I can’t see in Lens the actual status. The VM cluster works fine, because I have all the metrics in Grafana.
The Key point here is the Victoria metrics mode, with a single mode it works fine, but with the cluster mode doesn’t.
I tried to configure Lens with
Metrics Source - Prometheus
Prometheus - Helm 14.x (Helm)
Prometheus service address - monitoring/vmselect-vmcluster:8481/select/0/prometheus (tried even with double \ monitoring/vmselect-vmcluster:8481//select//0//prometheus)
Any success stories on how to make it work?
I really appreciate any help you can provide.
Hello @tkudinov,
Thanks for your reply.
Yes, I have Victoria Metrics Operator installed.
Today I updated it to the latest version, to be sure it is not a version issue.
After updating, I tried your option with Helm 14.x and the service address, but I still haven’t had any luck.
I don’t have Prometheus Service, I have VM services.
This is the settings
And here I don’t see any metrics, but the service configuration looks good
There will be a Lens release out tomorrow which has “Custom Path Prefix” configuration option which you could set to /select/0/prometheus. Hopefully that fixes the metrics for you.
