Hi, the metrics does not show up in my case.
I think it is because the spec I use has routePrefix in it
apiVersion: monitoring.coreos.com/v1
kind: Prometheus
namespace: kube-prometheus-stack-prometheus
routePrefix: /prometheus
I tried following metrics settings in cluster settings
PROMETHEUS: Prometheus Operator
PROMETHEUS SERVICE ADDRESS: monitor/kube-prometheus-stack-prometheus:9090/prometheus
and it is not working.
I got this in kube-api-server log, the requestURI is 404
"kind": "Event",
"apiVersion": "audit.k8s.io/v1",
"level": "RequestResponse",
"auditID": "*****",
"stage": "ResponseStarted",
"requestURI": "/api/v1/namespaces/monitor/services/kube-prometheus-stack-prometheus:9090/proxy/api/v1/query_range",
"verb": "create",
"responseStatus": {
"metadata": {},
"code": 404
the correct URI should be
/api/v1/namespaces/monitor/services/kube-prometheus-stack-prometheus:9090/proxy/prometheus/api/v1/query_range
Hi, this is a known issue/feature request. We plan to add a configuration option to Metrics settings which would allow setting a prefix to the url. Currently there is no real workaround.
Hi, could you try this service address:
kube-prometheus-stack-prometheus/monitor:9090/prometheus
this is assuming the service name is “monitor” - please adjust if it’s something else. It seems the namespace is kube-prometheus-stack-prometheus, not monitor.
Note that the input should be in form “namespace/service:port” but it should optionally accept a prefix.
