I have upgraded to LENS 6.4.0 and noticing that Namespace selections are not retained after exiting & restarting LENS (or) after disconnecting and reconnecting a cluster.
This looks like a bug to me.
Hi!
We just published a new version that fixes this bug!
Thank you for the quick fix !!
I took the latest 6.4.1 update this morning and I am still seeing the same issue i.e. after disconnecting a cluster or restarting LENS, the namespace selections in the dropdown are not retained.
The dropdown displays “All namespaces” instead of my selected namespaces.
This is with 6.4.0 and 6.4.1
Took the latest 6.4.2 update and still seeing the same issue i.e. after selecting specific namespaces, then next time the cluster is connected or LENS is exited and relaunched, the namespace dropdown displays “All namespaces” instead of the selected namespaces
This bug made its first occurence in 6.4.0 and not fixed in 6.4.1 or 6.4.2
@emeste looks like the issue is still there.
This issue is now resolved with 6.4.4 upgrade. Thank you.
Hi! Thanks for your feedback! ![]()
