Hi all,
Hoping for a little help.
I am experiencing an issue with updating Lens from a working version of 2024.9.300059-latest to 2025-1-161916-latest. As soon as I upgrade it opens and loads Lens and I can see all my cluster and connect without issues but as soon as I close Lens and reopen I am presented with a blank screen. It’s just a big grey box with nothing, no top menu, no side bar, no nothing…
Only way I can get Lens working again is if I revery back to the previous version.
I’ve tried clearing out the Lens data folder i.e. C:\Users\MyUser\AppData\Roaming\Lens and it loads I reconfigure everything and as soon as I close and reopen is it back to a black screen again.
I am on Windows 11, I pull my kube config in from WSL which has never been an issue before and I also overwrite the binaries location to set to my chosen kubectl install.
I don’t seem to see any notes of interest on the release notes so at a loss as to why I am experiencing this.
I can see that airgapped mode is enabled but greyed out. It seems that at the beginning of the year the license renewed and changed from enterprise to pro.
There is no reason for this airgapped mode to be enabled. If this may be the cause of my problems how can this be disabled? Or if this feature can not be disabled how can I get Lens working on the newer version?
I also encountered this problem. There is no k8s configuration on my device. I installed the version given on the website today and encountered the same problem. I am an individual user and cannot contact customer service.
I had the same issue after updating - reading this I then resorted to trying the google AI suggestions of Cmd/Ctrl+R to for a reload in the blank window and surprisingly that worked for me.
