Port Forwarding an active port could be made more seamless
When you Port Forward an active port that may be forwarded in another cluster or the current cluster, there should be a popup that says this:
“You currently have a port forwarded on Cluster x in Pod x, do you want to stop this first?”
(make this wording look better and more understandable I just wrote it up)
YES OR NO
There should also be a checkbox: “Don’t ask again”. When this is checked, when you forward a port, it will automatically stop the existing port you try forwarding to, no popup needed.
Why should this be done?
Well, currently when you try to port forward a port you may already have forwarded for debugging purposes in another cluster (e.g. 5005 which is shared a lot), it just errors with “Error occurred starting port-forward”.
I think this would make things a lot more seamless when remote debugging with lens, and Lens is already a great app with great quality of life features so I think it would improve it greatly.
Dear @lkjcdjklvcxkjl
Thank you for reaching out to Lens Support!
We will be sure to update our development team about your request.
Regards,
Oleksandr from Lens Support
