I didn’t see this issue in the known issues list so I’ll raise it.
If I create port-fowards, after sometime, they do not show up in the list, despite still being available and active.
The only way to remove the port-forwards is to quit and restart lens.
Hello @woodywoodsta, thank you for your feedback. Could you please send me your beta version? We have provided a fix for this issue in both the stable and the current beta versions.
Hey @crothmannmain
This is what I see in the about section:
Lens: 2024.7.161230-beta
Extension API: 7.0.23
Electron: 31.0.2
Chrome: 126.0.6478.61
Node: 20.14.0
Could you please try out the new beta version → 2024.7.261152-beta? (just published) Your feedback would be greatly appreciated!
No improvements unfortunately on 2024.7.261152-beta
. The list is still empty.
I concur. The same happens to me. A pod is port-forwarded and you can see this in it’s details. Network->Port Forwarding shows “Item list is empty”. I know the port-forward is present because I can use it.
Lens: 2024.7.261152-beta
Thank you for your feedback. We can understand your concerns and have already forwarded them to our development team. The fix is firmly scheduled for the next sprint, which begins next Monday. Our “Known Issues List” will be updated accordingly.
