Important Notice: Understanding Lens 2024 Early Access
The Early Access release of Lens 2024 is a sneak peek into what we’re building, not the final product. It’s an opportunity for you to experience the future of Kubernetes management as we explore significant UI/UX enhancements. This version is part of our development journey, and we openly invite your feedback to refine and perfect the experience. Please be aware that you may encounter bugs, and rest assured, we are dedicated to addressing these as part of our ongoing development.
Your input is crucial in shaping the final version of Lens 2024. We’re committed to evolving based on your feedback, laying the groundwork for new features that will redefine Lens’s user experience. For a detailed understanding of what to expect and how you can contribute to making Lens 2024 truly groundbreaking, learn more here.
Here is a list of known issues of Lens 2024 Early Access version updated May 06, 2024
Cannot shell into local cluster nodes - minikube/Lens Desktop Kube (#1870)Infinite loading spinner on cluster overview when no metrics or false settings (#1823)Functions are missing on nodes view and its details panel (#1866)Functions are missing on pods view and its details panel (#1868)Switching between tabs is sometimes inconsistent (# 1603)Doughnut controller is broken after first Lens startup (#1400)Kubeconfig validation is too strict, not all local kube configs are displayed (#1998)Port-forwarding is broken (#1637)Try opening ‘Kubeconfig File’ on Service Account Details Panel error (#1848)Jumping UI on drag and drop main view tabs (#2293)Wrong tab content is shown (#2178)Using icon color picker on cluster settings page crashes Lens/stresses CPU (2119)Don’t display Loading indicator when tailing logs (2189)Optimize cluster iframe view switching (2289)User has no possibilty to remove cluster from space (#2100)Cannot disable Lens metrics on cluster settings page (#2091)Jumpy mouse selection behavior in logs (#2195)Warning icon in Overview goes to page that doesn’t exist (#2179)Terminal stuck on ‘Connecting …’ takes quite long (#1910)Updated bored-agent image (#2326)Wrong positioning of pod and container filter selector in logs (#2353)Applications view doesn’t show up - Lens shows cluster overview page instead (#1986)Inability to persist cluster name changes and uploaded icons (#2193)Architecture changes after updating from stable to beta version (#2416)- Data from Hotbar is not migrated properly into Lens 2024 (#1698)
- Missing pod metrics on Lens Desktop Kube (#811)
- Cannot open any resources from ‘Security Center’ or 'Applications '(#1796)
- Open Lens Desktop Kube cluster view from bottom menu will open two tabs and cannot be closed (#1585)
- Refreshing Lens by using ‘CMD+R’ can break UI (#1995)
- Open LDK cluster view from bottom menu will open two tabs and cannot be closed #1585
- Running Lens Desktop Kube profile not visible in navigator (#2225)
- Failure to open running Lens Desktop Kube profile on LDK settings page (#2224)
- Open Lens Desktop Kube cluster view from OS menu does not work (#2216)
- Reopening a disconnected cluster after refresh does nothing (#2207)
- Navigator does not open or expand at the appropriate location when user clicks on an opened cluster settings tab (#2184)
- Lens cli doesn’t show (shared) clusters (#2167)
- Cluster connection doesn’t work reliably (#2160)
- Three-dots-menu closes automatically and flickers (#2102)
- AWS EKS Cluster connection is stale after laptop on standby (#1881)
- Missing ‘Security Center’ settings on cluster settings page (#1782)
- Shared pod link doesn’t work (#1702)
- Lens 2024 performance issues with multiple cluster connections (#2375)
- Auto-Connect failure after sleep mode (#2392)
- Missing pods chart for metrics fallback server (#2356)
- Metrics server (fallback) shows wrong timeframe (#2316)
- Cluster automatically disconnects for no obvious reason, reconnect not possible (#2317)
- Loss of connections to all clusters leads to inability to reconnect without restart (#2290)
- Performance degradation in Namespace selector in Lens 2024 (#2441)
- Delay in loading logs (#2444)
- Outdated UI elements in “Applications” Details Panels (#2431)
- Incorrect settings button link in Security Center (#2430)
