Spurious JavaScript Errors
20250304155437
Loads of these when running lens-desktop on openSUSE Leap 15.6 in Light-mode
They keep coming
(FWIW I am forced to use Kubernetes, namespaces and pods. I rather have simple VM’s myself, but customers require this, so I need a workable interface and found lens in light mode to be sufficient for me)
Hello @merijn.brand ,
Thank you for reaching out! i have contacted our dev team regarding your issue .
I think it has to do with choosing a font (DejaVu Sans Mono) that is not supported in lens-desktop (but my default font on all other stuff requiring monospaced fonts).
I removed everything, re-installed lens-desktop from scratch, selected light-mode and the errors where gone, which might render this issue to
feature request
  • enable choosing different installed fonts from the system
  • have a clear error stating the reason
  • make light-mode default on systems where the user env is light mode (no idea how to check, but very important to me)
FWIW, installing the rpm on openSUSE Leap-15.6 complains about missing libXtst. That is safe to ignore, as on Leap-15.6 the package is installed as libXtst6-1.2.3-1.24.x86_64 (version today). On TumbleWeed: libXtst6-1.2.5-1.2.x86_64
I am up and running again
