Uncaught Exception:
Error: dlopen(/Applications/Lens.app/Contents/Resources/app.asar.unpacked/node_modules/node-pty/build/Release/pty.node, 0x0001): tried: '/Applications/Lens.app/Contents/Resources/app.asar.unpacked/node_modules/node-pty/build/Release/pty.node' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64h' or 'x86_64')), '/System/Volumes/Preboot/Cryptexes/OS/Applications/Lens.app/Contents/Resources/app.asar.unpacked/node_modules/node-pty/build/Release/pty.node' (no such file), '/Applications/Lens.app/Contents/Resources/app.asar.unpacked/node_modules/node-pty/build/Release/pty.node' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64h' or 'x86_64'))
at process.func [as dlopen] (node:electron/js2c/node_init:2:2107)
at Object.<anonymous> (node:internal/modules/cjs/loader:1356:18)
at Object.func [as .node] (node:electron/js2c/node_init:2:2334)
at Module.load (node:internal/modules/cjs/loader:1126:32)
at node:internal/modules/cjs/loader:967:12
at Function._load (node:electron/js2c/node_init:2:13357)
at Module.require (node:internal/modules/cjs/loader:1150:19)
at require (node:internal/modules/cjs/helpers:121:18)
at Object.<anonymous> (/Applications/Lens.app/Contents/Resources/app.asar/node_modules/node-pty/lib/unixTerminal.js:29:11)
at Module._compile (node:internal/modules/cjs/loader:1271:14)
I’ve redownloaded the official version of Lens and reinstalled it, followed by updating from the Beta Channel (multiple times) and I’m met with the same error.
Specs & Operating System
2019 MacBook Pro (Intel based)
MacOs Sonoma 14.3.1
