Impossible to log in Lens
Hello. I have downloaded a new version of Lens (2024.1.170738) and I cant log in using my GitHub account or company address. The error is “502 Bad Gateway Host Not Found or connection failed”. Do you have an idea how I can log in or reset my credentials? Thx.
Hi @vrevsstatyana, thanks for the report. The build you have (2024.1.170738) is from early 2024, well before the current Lens. The current build is at Lens – Download (that’s the official source) – please install it and try again from there.
