Screen flickering and only partly displayed
Since an update in November my Lens Personal does flicker while having updates on the Workload Overview and other screens. Especially when changing tab from menu. If nothing happens on the screen it will be usable again.
I did do an update today and same behaviour.
I am running a Win11 with GTX4090 environment. All updates have been applied there.
Not sure, how I could describe this more precise.
Thanks,
Wolfram
Hello @wopl , i have contacted our development team regarding this issue .
Thanks for your feedback @wopl!
Does the flickering occur only on tabs that contain charts, such as Workloads → Overview, or also on other tabs like Workloads → Deployments? I assume you’re using Lens version 2025.1.161916-latest? Looking forward to your response.
@crothmann Interesting… I only did a quick check. Yes it seems mostly to flicker (and after 2 seconds or so it comes to a stop) especially tabs containing charts. Nevertheless changing tabs (e.g. from Deployments to Pods) some frames within the screen (top menu or so) will be black and after some 1/10s seconds refresh… so no smooth transition.
Thank you again for your feedback! I completely agree with you. We’re working on improving this to ensure smoother transitions and a better user experience.
