Hello!
The recent release of Lens Desktop that introduced all new UI / UX is the most substantial update since its inception and in our drive to deliver major improvements, we may not get everything perfect right away—but rest assured, we’re deeply committed to making Lens the ultimate tool for Kubernetes users.
Transparency is key, and we’re committed to being open about where we fall short and how we plan to improve. Your constructive feedback isn’t just helpful—it’s essential, and we encourage you to use these forums to share your thoughts and ideas. We deeply appreciate your patience as we continue to iterate and enhance Lens, and we’re incredibly grateful to those who are passionate about the tool and take the time to engage with us. Let’s keep the dialogue open as we work hard to make Lens the tool you’ve always loved—only better.
Known issues we are currently working on
Fast Cluster Switching:
- We are continuing to refine the experience to bring it on par with the legacy Hotbar functionality.
EKS Clusters Missing
- If EKS clusters are missing, try to update aws cli to the latest version and recreate the kubeconfig file.
Issues we have already fixed
Mixed Tabs Across Multiple Clusters:
- Tabs and the Navigator are now colorized to simplify cluster identification.
- The “Contextual Tab Filtering” feature will automatically filter tabs based on scope, reducing visual clutter.
Dock Functionality:
- Terminal, logs, and other dock features should be scoped to clusters rather than individual tabs.
Kubeconfig Management:
- Adding a
kubeconfigfile is not currently possible via paste.
- Adding a
Kubeconfig Compatibility:
- Kubeconfigs using
client.authentication.k8s.io/v1alpha1are not displayed in the Navigator.
- Kubeconfigs using
Performance Optimization:
- Improved performance when opening tabs.
Cluster Search:
- Restored the ability to search for clusters efficiently.
Command Palette Functionality:
- Missing commands from the legacy version have been reintroduced.
EKS Cluster Tabs:
- Tabs from EKS clusters now restore correctly after connectivity issues.
Theme Usability:
- Resolved usability issues for both Dark Theme and Light Theme.
Navigator Usability:
- Kubernetes resources (e.g., Nodes, Workloads) are difficult to identify due to missing icons.
Namespace Selection:
- Some users are unable to select namespaces within the UI. For a workaround define the accessible namespace in cluster settings.
